pj1969
hello again guys, hit a little problem.... I've just changed my 3 FUTABA 3010 servo's for 3 HK heavy duty digital ones, 2 are fine, but the 3rd which is the elevator servo, the linkages are not lining up,As you look at the servo horn, the link above and bellow the center bolt are a couple of mm off. i've looked at both servo's and the FUTABA horn gear that you attach the horn in about 3-4mm off. i'v connected it but the ends of the ball links and center of servo dont line up. I've made up a new link which is slightly smaller to try and bring it all back in line, but i seem to be not getting the same servo movement. Do the links have to be the same size or can one be slightly diff length and be adjusted in radio or is it critical to get them the same????? As always any help is great
