Spektrum Spektrum remote receivers binding
orton21
just a quick question. when binding the remote receivers to my dx7s on my trex 550e dfc they both go solid like they are suppose to. but when i unplug the battery and reconnect it one will be solid and the other will flash slowly. is this a bad connection or is this normal.
They should both flash slowly. Slow flashing is an indicator that the Rx lost signal with the Tx. Not sure why one is showing but not the other.
because you broke the signal. any rx and tx turn radio on frist then plug in batt. and to shut off is the opposite. it happens to me and my dx7, you have to turn off the radio and turn it back on then plug the batt in and it should be solid again. you can not break the transmission from the tx to rx. if you do you have to reinitialize.
