Venturi-XR
i'd just recently got done with some maintenance on the suspension including pivot balls and axles joints and bearings and such and i coat them with axle grease and it worked well and i also make sure the bearings got enough axle grease and so it wont take that much wear and tear until i replace them and i am still in the process setting up the HSN and LSN and thats because it wont go into 2nd gear and no its not the 70 tooth spur gear and so anyway i need some help for the carb settings for HSN and LSN to make it go into 2nd gear and should i turn in or turn out for the HSN and LSN by how much and i know this not got to do with suspension maintenance, but it wont hurt to ask anyway
