ilikeplanes
Hi, referring to the attached image, I am struggling to understand the best way to level the swash.
Attached image I have the 3GX in direct mode at 50% throttle (centered)
I understand that I need to make the servo arm 90 degrees but you can see it's to low. Problem is if I turn the servo connector up one notch it is then pointing above 90 degrees, it wont sit exactly because the ratchet on the servo is either slightly above or below. Any advice? It is the same on the other servo on the other side. You can also see the swash leveler in the pic, and I think if the servos where at 90 degrees it would almost be level.
Second question, I have hovered this a couple of times for a very short period, can you see the wearing on the top of the Main Drive Gear? Is that normal on the first use? The gear looks lined up properly with the drive nut.
Thanks
Thanks
