Trucks t-maxx toe adjusment
WazabiQc
I went to the Rc shop tonight, then the guy told me i should adjust my toe, said i should have a toe in setup. Could any of you tell me how am i supposed to adjust those to be symetrical ? and what recommended setup do you use for front and rear ? thanks.
wow ! thats a nice tutorial. However i don't have any adjusment tool, and my local shop doesn't hold that much stuff. where can i order those ?
Make sure to follow the instructions in teh video to set 0º of toe on the rear first, then by adjusting each side exactly the same, take it to 3º with the turnbuckles. You can set the toe with this tool
To adjust your camber, you can use this tool
Both of those are the exact tools that I used in the video. You will have to put a carbon rod or something on the camber gauge for it to work on the Maxx wheels as I did in the video. Hope this helps.
