holtneil
Hi guys have a strange one well it may not be to you in dec last year i fitted a new metal gear digital servo to a 450 fbl heli
i have a xyz gryo and i have always had a little bit of drift on the tail , its not as locked in as a HH gyro ,but its was ok
and it was running on 62% gain on gyro with no wag
the other day i was flying and heli was all over the place like it was in rate mode , so i landed and checked it and gyro red
led was on for HH mode so i took off and it was om but a little drift again
So i put heli on turn table and spun it up if you pushed on the tail the tail blades would change pitch and push heli back to
were it was , so today i was out flying in strong wind and yet again heli was like it was in rate mode even tho gyro was now
at 92% gain the tail does not wag even at 100% gain and tail does not hold at all any wind will spin heli round
So is it the tail servo thats gone or the gyro ,i have fitted a new servo just in case but cant test till i get now feathering
shaft , i am a but worried it not the servo and heli will be out of control again if i fly it , the 3 axis gyro is working on
the swash ok i tested that part , the only other thing i can think of doing is unplug tail from xyz and refit HH gyro on the
tail so the xyz is only doing the swash , i dont fly 3d so gyro is never working the servo very hard so a gutted if its gone
in less than 6 months unless this is all tail servos last for ?
kind regards neil
kind regards neil
