Hi all,
I'm doing a flybarless conversion on my 450 3d. I got a tarot DFC head. But I'm having some issues and hoping someone can help.
First, the shaft that came with the head is way too short. The blade holders dont even clear the anti-rotation bracket. Is there a shaft I can get that will fit this properly? I dont really have the hardware to be able to cut it and drill a new hole.
Second, it seems like the links on the blades holders that connect to the swash are way too big for the holes in the stock swash. Anyone know where to get the correct links or the correct balls to put in the swash? Or should I just get the tarot swash?
Thanks
Thanks
