Rico
Hi again, i just discovered a problem with my new TB70, when im on the field with blades on, and i spool up, the swash dont move, if i take off the blades and spool up, the swash goes up and down as it should, i cant seem to figure out what is wrong, it run on 2 X 6S 5200mah, brain 2 gyro, hobbywing 180A V5 esc with bec set to 8 volts, kst X20 servo set 3 X 2208 and 1 1035 for tail, Aligen dominator RCM-BL800MX 570KV 4530, if i give full throttle i can see in brain programe, that i can only give max 1750 RPM and it should have 2200 - 2400 RPM, if i use brain gonover, it goes up and down in RPM.
Any one know what could be the isue ??
Thanks from Rico
Thanks from Rico
