Trucks Throttle not consistent
anyoldiron
purchased a Bezgar model BZR1 1/10th scale rc truck for my grandson. Truck works fine until it stops when bumping into something Then the throttle wont function unless the wheels are moved by hand. It has a brushed motor. Tried tapping motor to see if maybe the brushes were worn, but nothing. It will only run when rear wheels are manually turned. What could cause this besides the motor. Battery is new and fully charged.
Everything between the motor to the ESC ( motor controller ), receiver and battery. Any loose connection or faulty part in any of that can cause problems. I'd also lean towards the motor based on your description and the fact you can turn the motor slightly and it works again.
