Trucks Tmaxx tips please
Ricky Minaya
Ok, take a full charged 7.2v battery and plug it in to the hand held ez start Unit. Take the hand held unit and plug it in to the hole at the top of the rear shock tower, and push the button, that should turn over the engine. While pushing the button on the hand held unit put your finger over the exhaust port. This will prime the engine. Push the button again and the if it doesn't start repeat again and again until it fires up. Any other questions
However, don't repeat the Plugging of the exhaust. Look at your fuel line and when you see fuel reach the carb, let go of it. Also, you need to make sure you have a red light on the starter letting you know your glow plug is working. However, if it starts and then dies, you could have a bad glow plug as I did. If it's been a while, I would just replace it to keep from having that headache.
