Hello Guys
Am in troubles again, I went out with my Trex 550 to test new blades and everything was okey but after the 7 battery I notice some uneven wear on the main gear and also motor was hot more then usual so I check the main gear with pinion mesh and was in same way I left it in build process but for some reason now there is axial play on both gears that it wasn't there before cause I check that when I install jesus bolt and please see attached video
it would be good to hear some advices before taking all apart
Your help will be very much appreciated
[video]http://youtube.be/b14iEI&Wb18[/video]
