Trexx 450
Rolando
Hi need help again , first blades werent spinning then switchd two wires around then it did spool , now my swashplate i cant get it straight . Barely moves thanks ,bty hear a buzzing sound
Hi Rolando,
The buzzing is probably a servo under load, it will burn out if you keep doing it.
Firstly you need to tell us what you have we know it is a T-Rex 450 but what is it Fly Barred or Fly-Barless, what servos are you using, what Transmitter & Receiver, what FBL system if it is Fly-barless, armed with this information we may have a better under standing of your problems.
Also have you looked through Tony's setup videos, they may solve your problems.
Rolando
Srry , its a flybarless . Servos are ds430m . Tx dx6i and rx 610 3gx
Receiver spectrum ar610
Hi Rolando, if you go to "Articles" in the top Menu on this page then select "3GX How To" you will find all of Tony's videos on how to correctly setup the 3GX, the software versions make a big difference, I'm happily using Version 5 but other swear by version 3.1 but that has to be taken off very quickly.
http://www.rc-help.com/content.php/360-3gx-how-to
