500 TX 16s Radio
MurryB
Hi to all.I have a Trex 500 with FBL head. I want to use my TX16s transmitter on it what do i use for a receiver. I have AR7210BX on it right now?:moody::nightmare: Sooner or later I will be putting H1 controller on it.
fran11784
Can't you bind to the AR7210? Pretty sure the TX16 is compatible. Probably have to go through the whole setup again but no biggie there. Never had a Radio master TX so not entirely sure here...
I'd point you at the manual for your TX ... the AR7210X is a DSMX receiver so it should work. Configuring the FBL portion is probably the only thing in question but I suspect that isn't configured through the TX.
