General Valiant 1.3m
Blade93
I am in the process of swapping over to a dx6e (from a dx6i). I am binding such that I can SAFE select 'ON' (as per page 10 of the manual). Most everything seems fine in that I reach a point where when i turn the radio on and power the receiver, the surfaces cycle back and forth TWICE to indicate that SAFE select in switched ON. So far, so good. I would then expect to see the control surfaces react quite a lot when I turn the plan upside down (as if trying to self-level), but there's nothing happening at all. I had a two-position switch successfully used to toggle SAFE on or off (when using the dx6i0 but can't replicate that with the dx6e - why??
