Other Walkera Devo7
Biglion
Hallo My Name Is Eyal
i buy the walkera v450d03 with the devo7 combo
in the first is ok for begginer until you crash
i buy spare parts and fly it again but it's not good at all
so I decided to buy another bird
i Bought new rx rx1202 12 channels by Walkera to bind with my Devo7
and Copterx 450 Pro V5 Flybarless DFC KIT
3 x Align DS416M Digital Servo for Cyclic
1 x Align DS525M Digital Servo for tail
1 x Align 3GX Flybarless System
1 x 3500KV Motor 450 Size Helicopter
So I'm asking for help
With the ALIGN 3GX FLYBARLESS SYSTEM AND DEVO7
Thank you.
i forgot to tell you all
i have 60A ESC - HOBBYWING PLATINUM and 90A CASTEL TALON
what to use in this bird
Really for a 450 sized heli anything I've 50 amps is not needed. If you use the standard 450mx motor by align then a 40 amp esc will work.
A 12 channel rx is going to be huge. It may not fit in the frames. I have a 9 channel that does not fit and an 8 channel that does.
Going with align electrics is a great choice. For the most part they are reliable and sturdy. They can take some punishment. As for the 3gx don't be to surprised if it does not work right away. People have been having issues with the fbl system. Some 3gx folks have moved on to microbeast, ikon and possibly Bavarian Demon.
Good luck and keep us posted as to your progress.
Biglion
:thinking:
hi again I want to ask you what Pitch curves and throttle curve to use on my transmitter for setup 3gx in first time
what is a linear curve and what is 50 in and 50 out on the throttle mid stick ???
in my first 450 heli to setup 0% pitch I use idle up 1 in mid stick (idle up 2 is the same idle up 1 setting)
how to do it in 3gx for first time ??? in normal mode or idle up 1
and can I use dual rate and expo on 3gx ???
this is my setting for my walkera 450D03 on my DEVO7 Transmitter
The settings are :
at SYSTEM tab, go to STMOD > MODE 2, then press "ENT"
at MODEL tab, go to SWASH > 1-NRM, then press "ENT"
at FUNCTION tab, go to REVSW > ALL THE channels are NORM
at FUNCTION tab, go to TAVAD > All default 100%, do not touch
at FUNCTION tab, go to SUBTR > All channels are 0.0%
at FUNCTION tab, go to DREXP > Channel ELEV, POS 0, DR : 100%, EXP is Linear, rest remain untouched.
at FUNCTION tab, go to DREXP > Channel AILE, POS 0, DR : 100%, EXP is Linear, rest remain untouched.
at FUNCTION tab, go to DREXP > Channel RUDD, POS 0, DR : 100%, EXP is Linear, rest remain untouched.
at FUNCTION tab, go to THCRV > SRVHD YES > MODE NORM, EXP ON
P-L : 0%
P-M : +60%
P-H : +100%
at FUNCTION tab, go to THCRV > SRVHD YES > MODE ST 1, EXP ON
P-L : +100%
P-M : +80%
P-H : +100%
at FUNCTION tab, go to THCRV > SRVHD YES > MODE ST 2, EXP ON
P-L : +100%
P-M : +80%
P-H : +100%
at FUNCTION tab, go to GYRO > MODE MANU, SWITC : FMD, POS 0 : 80.0%, POS 1 : 80.0%, POS 2 : 80.0%
at FUNCTION tab, go to PTCRV > SRVHD YES > MODE NORM, EXP ON
P-L : -16%
P-M : +20%
P-H : +55%
at FUNCTION tab, go to PTCRV > SRVHD YES > MODE ST 1, EXP ON
P-L : -55%
P-M : 0%
P-H : +55%
at FUNCTION tab, go to PTCRV > SRVHD YES > MODE ST 2, EXP ON
P-L : -55%
P-M : 0%
P-H : +55%
please tell me what you think
I need to select new heli on my transmitter and name it 4503GX
and I Waiting for your setting help
thanks again
Biglion
:thinking:
The settings are :
P-L : 0%
P-M : +60%
P-H : +100%
P-L : +100%
P-M : +80%
P-H : +100%
P-L : +100%
P-M : +80%
P-H : +100%
P-L : -16%
P-M : +20%
P-H : +55%
P-L : -55%
P-M : 0%
P-H : +55%
P-L : -55%
P-M : 0%
P-H : +55%
thanks again
hii
I need help to connect walkera rx1202 to align 3gx ???
please any help thank you
I wish I could be of more assistance. I have very little knowledge of the 3GX system. Here is what I can tell you:
Throttle Curves (I will list three: Normal, ID1 and ID2 [you may not have an ID2])
Normal: 0 40 75 75 75 (you can play around with the 75 number to give yourself the headspeed you want in the end.)
ID1: 70 70 70 70 70 (same as with normal these numbers can be adjusted to suite your needs)
ID2: 80 80 80 80 80 (You may not have an ID2 if you do then use these numbers.)
Pitch Curves
Normal: 45 47.5 50 75 100
ID1 and ID2 0 25 50 75 100
D/R and Expo
I am not sure on how to start you off here. I ham currently doing a massive upgrade to my kit and these numbers will be changing for me. you probable could start somewhere in the area of 35% D/R and 75% Expo. If that is feeling to sluggish around center stick then reduce the D/R by 5% until you get the feeling you like.
TimD
Hi, I noticed your 'pitch'curve settings,..i have a devo 7 tx also .but the pitch curve 'values' are -16 to +55, the values you show don't indicate 'minus' or 'plus' values! Can you please explain were the 'minus' and 'plus' values go? Thanks!
