Batteries What Is This Cable?
that is a series cable. Just commented on this in your other thread. You will plug that into the balance port of a 2s charger, but you will need to connect the red and black wires to the main ports of the charger in order for it to work. These work best on those cheap balance plug only chargers you get from china.
Ok. This cable is really why I posted the question in the other thread. I was thinking it was used for that but the way it is wired had me doubting it.
yup, it just makes a 2s pack that you can balance charge. Instead of raising the amp rating, you just raise the voltage.
