Me too my friendCan't wait for the next test hover![]()
Same here in supposedly sunny FLA...Mother Nature has not been kind to us
Depends on who made the motor. I want to say 6 but that's not accurate because I am guessing. There should be a data sheet that will tell you. Sometimes the retailer will list that as part of the description.does anyone happen to know the magnet pole count on a F2835 motor that fits a 450 size helicopter? Shooting for a lower head speed, pitch is no problem. We're real close and believe me building a scratch bird is no joke. Everything has to be spot on but that's the beauty of the hobby. Thinking out side the box![]()
I was going to suggest the same amountI want to say 6 but that's not accurate because I am guessing.
Hi there friend, we looked up this motor on line and found a data with a lot of information but nothing on the magnet pole count. D.O.G sent me a text on you tube that may have the answer. I was off by two teeth on the main gear, correct count is 150T. Replace the 13T pinion with a 11T one and also removed the tape stripping from the 360mm blades. We'll put on plastic 325mm blades for the next spool up and hover test. Once this issue is resolved successfully, replace them with the original 360 carbon fiber blades. Since fran11784 reprogram the Talon 60, the slow spool up is something to see and enjoy. Best regards, JimDepends on who made the motor. I want to say 6 but that's not accurate because I am guessing. There should be a data sheet that will tell you. Sometimes the retailer will list that as part of the description.
Just reviewed the link you sent me, and both fran and I along with murankar are looking at a 6 pole setup. Team work babyI was going to suggest the same amount![]()
That's what help in RcHelp.com is all aboutTeam work baby
