callsign4223
You know that wonderful backlight you put into the dx6i, well the hot glue holding the transformer in place let loose and the transformer was banging around inside the case. One of the wires broke loose from the transformer while it was swinging around. I need to know where it needs to be soldered back on.
There are 2 red wires soldered at the red circle
There are 2 black wires soldered at the black circle
There are 0 wires soldered at the blue circle, but it looks like there used to be something soldered there
So, which circle do I solder this extra red wire to? Or is it somewhere else?
Colors are kinda hard to see, sorry. Just lean close to the monitor
