I do not have a camera system yet. Not sure what direction I want to go next put it on this frame or build an octo 1300 mm machine. What do you all recommend?
Hi Kevin, I'm using a GoPro clone on a 2 axis Gimbal, it works OK but I'm having issues with vibration causing the jello effect, I know I need to balance props (already done) & motors to fix it but frankly I'm loosing interest and focusing more on Helicopters again.
But I would recommend buying the best equipment that you can afford for the best results.
