Hey guys. I have a Redcat Caldera 10e and lost one of the screws out of the front steering knuckle or Hub. Not sure what it's called. So I bought a set of aluminum ones. However I find that the steering binds when I tighten the screws. Now it came with aluminum bushings that I basically had to press into the old holes. My question is should that mounting screw free float inside of the bushing? It seems like that would be what should happen but what I have seems to almost thread into the bushings as you can see in the photo. That screw is threaded in the bushing. I could take my Dremel and just relieve the inside of the bushing a touch if that's what I need to do, but I'm not sure at this point. I thought it prudent to consult someone with a little more experience before I proceed. Thank you in advance. I apologize if this would be considered a tech question.
