I have a Futaba 14SGH, under pitch curve on normal rate is set at +30% by default. The next page shows low pitch & high pitch by default they're set to INH and rate is +30% on both side. I'm just having a little issue with my HELI, just when I'm trying to pitch down and about pass below mid stick it has a fast descent so when I'm trying to compensate the HELI has that bouncing like up & down effect like its loose right on the middle and not really connected to your stick about mid point. Now my question is, if I switch those low and high pitch to on and change the value to -15% on both side, would it help smoothen my pitch around center?
Pls help, thank you so much.
Regards,
Ricky
Regards,
Ricky
