What's up everyone. Well, I have been asked time and time again what the KV means on the side of a motor. Well, this video will explain it really quickly. It's a simple equation that you can use to figure out your head speed as well.
Pretty much, if you have a 3500kv motor, then that means it will turn 3500 rpm if only 1 volt was applied and it was running at 100% efficiency. Lets face it though, nothing runs at 100% efficiency, so in these, we are using 80% to be safe. If you want, you can use 90%. Below is the equation.
(kv*v/(m/p))*.8
Confused yet, don't be.
kv= the kv rating of your motor
v= the voltage of your battery
m= main gear teeth
p= pinion teeth
If you use this equation, you can figure out what kv motor you need for the perfect head speed, and with what pinion without ever buying a motor before hand.
(kv*v/(m/p))*.8
m= main gear teeth
p= pinion teeth
