I've left messages in the past, but have yet to receive a return message, but will try again...thank you for the response!!Have you contacted Spektrum tech support? They should be able to assist.
Great info......I've recently experienced some odd issues popping up from time to time....so thought there might be a corrupted file on board, so figured I don't have that many birds, so Hard Reset and start over.....the radio it's self has been NO ISSUE since I've owned it....but it did sit for close to 2 years with no use.....thanks for your reply.....I'm gunna attemp to update, so may be an opportunity there to sorta reset....As far as I know, there is no factory reset per se on Spectrum radios, or at least one available to the general public.
You can reset each model one at a time per the user manual ( see page 17 ). I've also read that you must leave at least one model on the radio. If so, create a new blank model of your choice ( acro or heli ) , leaving it's settings blank and reset all of the rest.
DX8 User Manual - https://www.spektrumrc.com/ProdInfo/Files/SPM8800-Manual_EN.pdf
The only other thing to reset after that would be the user name listed in the system area.
That's what we do, support each otherI've left messages in the past, but have yet to receive a return message, but will try again...thank you for the response!!
LOL...thx JamesThat's what we do, support each other
