wizzard363
Decided to have a go at a scratch build and went with balsa instead of foam
No plans , no drawings , just a pile of balsa and a scalpel.
The only guide I used was a leftover rib from a J3 lazer cut kit I got from hobbyking . I used the rib a guide for wing profile and bigger all around as I was going for a larger model .
My idea was to create something "cartoony"
The ribs were the first thing I started with then I glued a couple of balsa sheets together and cut out a fuselage .
I knew from the start that the short nose would make COG hard to achieve but the idea I had in my head came first and the practical side would just have to work itself out
In the end it needed 200grams of lead in the front but I am happy with the way it worked out(I make fishing sinkers so there is no shortage of lead here)
I have bigger alloy wheels and alloy landing gear on order so will swap lead for bling soon
Wing span is 1550mm , motor is 900kv 3548 NTM motor , 12x6 prop and 4000mah 4S lipo
Still a work in progress and I will post updates
Maiden day was very windy but some things just can't wait
http://www.youtube.com/watch?v=ZxpjTLNFFsg
