Hello,
I'm Axel, a new member trying to build an electric skateboard. I am not sure how to use or even read the specifications on some of the parts I'm looking at. So far, I have a Turnigy Aerodrive SK3 - 6364-245kv Brushless Outrunner Motor, 2 ZIPPY Flightmax 5000mAh 3S1P 45C I was planning on wiring in series for 10,000mAh, and a HobbyKing® ™ 150A High performance Brushless Car ESC. I know that if the Amps across the various parts are too high then bad things happen, and if they're too low, even more things could happen. I'm then trying to control it with a Hobbyking IOS & Android 4CH WiFi Receiver, through my smartphone. I know that the ESC and the Receiver are both made by HobbyKing, but would they still fit together and work? Additionally, overall, would this system work as is, or are there any improvements you could suggest?
Motor: Turnigy Aerodrive SK3 - 6364-245kv Brushless Outrunner Motor (US Warehouse)
Batteries: ZIPPY Flightmax 5000mAh 3S1P 45C
ESC: HobbyKing® ™ 150A High performance Brushless Car ESC
Receiver: Hobbyking IOS & Android 4CH WiFi Receiver
Thank you and I appreciate any and all of the help you can give me.
