Ariel PandaMan
Good day.
I need an advice for the batteries because it was a 4 engine edf jet which is based on a boeing 747 -200 and its wingspan is 47.25 inches and it has (9 gram micro servos for the primary and secondary flight controls) 4 servos on the ailerons, 4 servos from the flaps, 6 servos from the krueger flaps, 2 servos for the elevator, 5 servos for the landing gear ( Landing gear retractable servo), and 1 servo for the rudder. Motors are from Turnigy 2815 EDF Out-runner 4000Kilo volt although I've found some 50 mm blades for edf which are counter rotating from RC castle which the brand of the blades are from QX MOTORS . The landing gear is based on the real boeing 747 which has 18 wheels, all wheels are 1 inch in diameter. And a airspeed indicator and a FPV camera.
