That definately not mg90s. Mg90s Is from tower pro. This is turnigy.. (but exactly same to the mg90s)
These servos are analog by specs..
Analog and digital both servos will "work" (move) on a digital only gyro. But the current coming from the gyro to drive your digital servi will not be right for your analog servi causing your servi or gyro to burn mid flight causing much more damage than just a digital servo.
So don't use that servo for tail, of switch to a gyro that supports both, either ways you'll have to order something.
And if your digital servo plugged directly in was giving u issues on other channels, then it is your servo.
Co incidentally, I used corona (500 size) on the tail of my 450clone, suggested by people here. And my servos for cyclic were mg90s. Do there isn't any compatibility issue as such.
The mg90s servo is a good little metal hear servo with Lot of torque for that size, but is sluggish to where the tail is not so stable. I had a gy48v plus mg90s on my tail before I went to a gy48v plus corona combo. I tell you this, corona digital servo served me much better than mg90s on tail.
