I have just found out to my cost, that the DS480 gyro is not compatible with Align gyros. Apparently when the gyro initializes it moves the servo from full left to full right to find the limits. The problem is, the servo sees this as an error and turns off!!!! The only way to fix it is to plug in the servo after the gyro initializes. A pain in the A$$ if you ask me. Should be in the HK write up.
