Hello everyone, I thought that I would make a video, that from start to finish, explains what you need to do in order to get a heli up in the air.
In this video, I started with my Dynam E-Razor 450 RTF with the FM radio. It's just me, but I don't like FM, but it was the only thing they had at the time when I purchased this heli. So, what better platform to test this on, right?
I started with taking the old Rx out of the heli, and plugging in all of the servos into the new Rx. In the video I also explain how to bind the DX6i, and how to setup all of the servos so that you get the proper pitch and throw out of the blades.
I also go through other setups like the throttle and pitch curves that I use, and D/R and Expo settings as well. In the end of the video, after all the other setup is done, I take it outside, and setup the gyro and tail. After just a few flights, this thing is rock solid. One thing that I overlooked, but noticed after shooting the video is the servo arm on the elevator servo. The ball is closer to teh center of the servo than the other two servos. This caused it to not have as much travel, and was the reason it wanted to pitch forward with the more throttle I gave it. This was just an oversite on my part, but has now been fixed.
I decided that instead of breaking this up into multiple videos, I would just to this in one video and call it done. I hope you enjoy it, and I look forward to hearing your comments.
