Hey , it was a year or more now that I almost exclusively used the rc help vid to build my first cheap 250 clone ,..the problem is now I want to build some more & I literally forget how to do it ,..so I was going through my programs & files & find that openpilot is no longer supported ? I had been ordering parts all winter & have a stack of cc3d controllers & frames ,..& now it looks like open pilot gcs is no longer used ? I found a new program called LibrePilot ,..seems similar
I was wondering if you could do a new updated step by step beginner vid ,..on a 250 build with the cc3d ,, with whatever is the easiest software for someone new to use ,..I was also going to try fpv ,..maybe another video showing how different pdbs can be wired up ,..also what do I do If I have a mix of parts like a transmitter that puts out 5v , but a 12v camera ? do I just pull the power pins from the cam cable & extend those wires right to the pdb & just run the vid cable into the tx ? also Im sure there is a way to import my saved cc3d config profiles to librepilot ,..I havent found out how yet ,..,..anyway my first cheap 250 is still flying ,..it was wired a bit messy I hope to do it cleaner this time
