Yes its playing okay I guess. Its finding the correct stuff for the build that's been hard for me.
As for ends:
On the awg8 and 10 I was thinking crimp on ring ends. These will allow for easy maintenance from inside the psu. Also thought of the 4 or 5 mm bullets for the opposites side of the wires. That power block is what I have been thinking of using. That will allow me to expand or configure output power without messing with the PSU. I was hoping to find something that would allow 4 outputs. I have to be able to jump from the block of one PSU to the block of another so I can make 24v 1050w at 47amps.
The pl6 also has ec style connectors. This is good and bad. The bad is that it introduces a fail point in the power system. If I have a fail point I want it to be a fuse not a connector. The good is that it is an ec style connector, firm solid connection that's hard to separate.
Wires:
I think an awg8 line would suite for the jumper that is used to make 24v. Awg10 line would be used for everything else.
I think 10 would work for the jumper because tony did his with 10 and charged a shloald of packs at 30amps just fine. 4 3s packs maxed won't even challenge the system at all.
As for ends:
Wires:
