Well, finally, I reached a "successful" test flight where now I just need to do some fine tuning. The three issues from its maiden flight needing to be addressed were torque yaw, COG, then after changing over to governor mode from fix end points I experienced motor RPM drop in mid flight.
I think we know the torque yaw can originate from gyro settings, COG is a no brainer but I was concerned that the motor dropping in its RPM's was either from being sold the wrong motor or the total gear ratio was wrong. The good news is it turned out to be the battery's C rating was too low. I borrowed the batteries from my Goblin 770, 6s c35 6000mAh and was evident from the second test flight (above) could not deliver the power needs under what I considered a mild load.
After checking the ESC's data log it was evident there was enough ripple to cause the ESC to begin protecting itself and limiting the power drawn. I then tested it with the batteries from my Goblin 630, 6s c45 3700mAh and within seconds it was obvious the problem was in the batteries. Although the new data log still showed some ripple the proof was in the flight.
I had to crop the pics considerably to get them to upload and lost the lower data info. The upper green line in the graph is the current being drawn, the black line in the middle is the throttle in and the lower purple line is the ripple created by the ESC to protect itself. In the "2nd completed 47 test run graph it shows a small but definite improvement in the ripple, but the proof is in the comparison between the second and third videos. Here is the link to the 3rd test video
Bell 47G Successful & Final Test Flight - YouTube
Incidentally, I was still getting some bobbing and the collective was very touchy , hence bumping the ground, but these can be fine tuned.
