Another question for the seasoned, this is still associated with the 300CFX. I have a crashed Fusion 360 BNF so I took the fc6250HX out and put it in the CFX. I just can't get the 7200bx to be my friend. So I put the 6250 bnf in the CFX. All surfaces move like they should EXCEPT the swash plate. This is something I haven't seen, the right gimble moves the pitch and roll just like it should but the throttle gimble is reversed. By that I mean when the gimble is down the swash is up but not the motor. The motor is still and as you push the stick up the motor revs up. But the swash is already at the top and it goes down. I thought it might be the ESC so I hooked up the original ESC out of the Fusion and still the swash is moving in the reverse direction. I wonder if this is something Horrizon Hobby has installed to make it unusable like I tried to use it. The FBL unit doesn't know it's in a different heli so what the heck?????? Just dumbfounded.......
Any advice would be appreciated.
