New to the site for help with my 300CFX - recently replaced a bunch of parts, stock servos with Hitec mg-5055's and a Spektrum 3020 for the tail and I am having trouble with getting it back into the air - some setting issues (reversing and servo direction) I am searching for help with. Still working with the stock ESC and AR7200BX Gyro. Hope to figure out the issue soon.
I reset the 7200 gyro to its factory defaults which are the 300CFX's settings (I did not update the gyro) and downloaded the TX settings for the 300CFX from the Blade site - both are set - but when I try to give it elevator it maxes out and wont lift instead reversed and pushes down. My forward is back and back is forward - right left and left right are backwards.
I tried messing with the reversing and changing the parameter's within the menu of the gyro - no luck in finding the right combination.
Thanks.[/QUOTE]
Thank you for the following reply.....
"Menu I in the manual is where you set your servo directions. If you reset the gyro, you must go through all setup processes and set everything up again.
Welcome to the forum. We will do all we can to get you back in the air. I have been wanting one of these helicopters for quite some."
Per the user manual of the 300CFX which lists factory default settings for the included AR7200BX..." The AR7200BX included with your Blade 300CFX helicopter is pre-programmed with these default settings. If you perform a factory reset on the included AR7200BX, it will default back to these Helicopter setting."
However, I did try to go through the menu using both the AR's Manual and RC-Helps YouTube video to both a new model and 300CFX TX settings. - I bound to a new model, went through the menu then bound it to the 300CFX settings - because per the manual Letter I - up/down /left/right is done in the TX setting and was not important....not sure what I am missing.
Thanks.[/QUOTE]
