I'm using Cleanflight not Betaflight so there may be some differences.
If I understand when you are on the receiver page you only see movement on the Yaw Slider ? (I assume your transmitter is Mode 2)
On the Receiver Page go to the Channel Map on the RH side a click the down triangle and select Spektrum / Gaupner / JR .
Hopefully that will change the mapping to the same as the Torrent, the instructions have been written for the later Transmitters that is why you can only get 125 on your Tx that is as far as it goes just use 125/125
I forgot to mention the throttle has input too.
This is the readings so far.
Throttle is 1026 - 1467
Roll is 1583 - 1976 with 1756 at the center reading.
Gear switch is changing the pitch reading from 988 in off position and 1358 on
I selected the Spektrum / Gaupner / JR setting as you said. I guess I am supposed to save after that? Am I supposed to do anything after that?
I still have nothing on the right stick yet.
After the drone is connected to the computer for a couple minutes, the drone starts beeping. Is the battery supposed to be connected while using Betaflight?
Thanks!
