Cars Brushless Dhk Buggy Off Road System
Will i need to upgrade my motor only or motor and other things(like gears, tires, etc)
  • motor only
    Votes: 0 0.0%
  • motor and others
    Votes: 0 0.0%
  • only gears
    Votes: 0 0.0%
  • Total voters
    0
Eli Haugh
Hello Everyone, I am asking any one for any advice on getting an rc 1/10 0ff road buggy to go very fast off road.
::Things you need to know:::
--I am using a 1/10 4wd DHK wolf 2 buggy
--I currently have a 3500kv brushless motor with 60 amp hobbywing quickrun esc
--I have a 3s lipo 5000 mah battery
--The buggy has about 1" ground clearance with battery
----I want to get my rc buggy to go at least 30mph on the grass(short grass) and not overheat the motor or esc while driving on-road and off-road.
I have a 17t 32p pinion, a 23t 32p pinion and a 53t 32p spur gear and my spur gear can't really get any bigger because the stock 53t spur gear almost touches the floor of the chassis but if i need to cut out the chassis to fit a bigger pinion than i will.
--I am asking anyone if you know of any brushless motors and/or any gear combo's that i could use to get a fast off-road speed and if i will need a brushless motor fan.
**The differential pinion is 11t, the differential spur is 41t and the tire size is 72mm(3 inches).*
Thank you for you help! I really appreciate it.
