Blackwarrior
Hi Paul, thanks for all your suggestions. When I got it all setup I ran it without the blades attached, got to half throttle and all seemed well, moved cyclic around and watched swash which appeared to move in all the right directions. No vibrations at all from it.. So put the blades back on the following morn and took it in garden.. There was nobody around at the time, wife was watching from bedroom window....I had no worries about hurting anyone, but certainly didn't expect to see what actually happened... I was extremely gentle with throttle and didn't touch cyclic prior to it jetting off skyward... Never touched throttle hold either..
My throttle curve in "normal" mode is 0, 56.5, 72.0, 72.5, 72.5
Hold is 10% throughout
Pitch curve in "normal" is 45.0, 51.0, 60.0, 73.5, 100
Hold is 42.0, 46.0, 50.0, 75.0, 100
I got these settings from the eflite user manual, but I've just seen an error with the pitch curve, I've got it set to 100% at full! and the manual is 91%.... I never reached anywhere near full throttle though so I'm uncertain this is the cause..??!!
Thanks for advice
Thanks for advice
