ESC Cc Talon 90
fran11784
Hey guys, I've been trying to help a buddy with a Synergy 516 issue. He's using a CC Talon 90 in gov mode and a DX8 gen2 transmitter. The problem is we only get two flight modes. that is we get 1900 normal, 2200 idle 2 and when we switch to idle 3 we get no increase to 2400. I've been though all his settings and it all looks good. Any other suggestions or things I might be missing.
Thank, Tony
The ESC isnt recognising the full throttle range. He needs to do the fixed endpoint calibration routine. .. I've had the same issue on castle ESCs
fran11784
We have not done the endpoint cal. Will do that, thanks
Yup probably should have done that in the first place. The reason I didn't was because a while back I was talking to Castle about a HV controller and he told me you really only need to calibrate the end points if you using the auto bail out function. Anyway it works thanks again...
T
