Spektrum Dx9 Airware Update
James Anderson
Updating my DX9 Black Tx. When I transfer the new .sax file on to my SD card, will this overwrite the old .sax file on the card, or is it necessary to delete the old file?
Also, I'm updating the sound file, and have ended up with an "English-v1-09" file. Presumably, that is inserted into the SD card as well. Again does the original sound file stay on the card, or should it be removed?
Thanks
Hi James, when you upgrade the system will rename the SAX file from in this case SPMTX.SAX to SPMTX205.SAX the Voice file will just remain the same name and can be reused if needed if a new version is issued it will have the next consecutive number.
