Harford
I have programmed in the Throttle Cut Option for one of my Helis. Selected Switch H, negative -130%. The function works when moving switch from position 0 to 1 (ie. I can see this on the Throttle Cut screen when moving the throttle stick). However, when I do this I don’t get a voice alert that I have moved from Normal to Hold, and the main screen continues to display Normal rather than Hold when I have moved the switch position. Also, there is no position H displayed in the Throttle Curve screen.
All this is in contrast to another model on the same Tx. Same throttle hold settings, Position H is displayed on the throttle curve screen, and voice alert when changing the Hold switch (H) from off to on,main screen changes from Normal to Hold.
Any help to solve this would be much appreciated
Michael
Michael
