fran11784
Hi all, finally getting around to the giant Align E1 Plus build. I have some pictures. I have to say this thing was definitely designed for lifting heavy loads. The top bearing block has a double radial bearing rather than just one. The frame is 82mm wide and the bottom plate is solid aluminum and 6mm thick. Also has the tin main shaft. Pretty cool. I will continue to update the progress.
