Stambo
I decided I could no longer wait for a spotter to be available to try out my new OSD.
On the weekend I got everything organised and just did it.
Just a quick test flight on my quad with my new G-OSD V3 hooked up and working.
Unfortunately settings in my laptop caused the bottom of the display to be cut off.
Excuse the poor video quality, I was in a bit of a hurry to upload it.
Props are unbalanced, just wanted to see the OSD working.
Return to base "B" works fine as long as you are moving, altitude reading is not super accurate but good enough for what I want. Also altitude does not zero to take off altitude so you have to remember and do some quick math.
GPS coordinates are in decimal format so need conversion to put in google maps.
Mine were within 3 meters.
For a $37.50 OSD I am happy.
I don't know what it is about altitude but at the moment I get freaked when I get too high and find myself doing a bit of a dive to get down lower. Hopefully that will improve the more I fly FPV.
I will have to do a bit of weight reduction as I only got 7 minutes with all the FPV gear on this quad.
Same battery that gives me 15 minutes on my basic X quad. I guess removing the big legs and sticking some heli landing skids will be a start. And maybe a BEC and run everything off the flight battery instead of running a dedicated battery for all the FPV gear.
http://www.youtube.com/watch?v=5oce9ax9ndU
