Awesome! I certainly can't give a real good opinion because I've not yet flown FPV. I was just mentioning what I've read.
To fly FPV on the 5.8ghz system...do you have to have the HAM license?
That set up from RMRC is almost the same. Just the goggles are an earlier model. Wider field of view, but lower quality picture,
For license free use in the USA, the video Tx's Effective Radiated Power is less than 1mW (.001W) and the Tx must have a valid FCC Part 15 Reg ID label on it. Otherwise, it will need to conform to the amateur radio rules.To fly FPV on the 5.8ghz system...do you have to have the HAM license?
+1 Goggles... It gives you a better feel that you are riding on your plane and or quad... They can be used with any size TX and RX no limit...
Even though I will be adding a screen to my Ground station for bystanders to watch....LCD 8" or 10"
I should have clarified. I was talking about the goggles that have the built in Tx. I know you can hook them up and ONLY use the video feed but something like the fatshark goggles that are all in one have no AV box on a ground station, only in the goggles.
