holtneil
Hi guys hope you had a great xmas , well i got my cobra body for my 500 pro , i am not impressed its poo for the money it cost , any way i got stuck in changed all parts from the pro frame to the cobra frame ,i put all servos in the same place on new frame , made all links the length align say 50mm well at mid stick with servo arms at 90 deg ,swash was not level .
So i levelled it had to reduce front links now its level at mid stick , at full throttle is not so used servo end points to level it but as you try to adjust it ( say the elev)the servo goes all the way down or all the way up ,then when you bring throttle down the pitch servo goes all the way up then stops , so as you adjust it, it then goes all the way down and the elev servo then start to go up
I re-flashed 3GX makes no difference
What the hell is going on when i built the pro it set up first time swash levelled ok was so easy to do now its a night mare , i know i am missing some thing ,i even levelled servos and swash in DIR mode sets up right but as soon as the 3 GX is set for flight the servos are all over the place again
Any ideas please
Any ideas please
