General how to choose the propeller for a brushless motor
bsuvansh
i am using AEW 3548 Brushless Motor 1100KV
its Specifications are :
RPM/V: 1100
Max watt (W): 911
Max Current (A): 50.3
Shaft Diameter (mm): 5.0
Weight (g): 156
Motor Size (mm): Ф35*48
Ri (Ω): 0 .023
Suggested Esc: Speed Controller 70 amp
Li-Po: 2-4 cells
Thrust:2150g
so i want to know that how can i choose propeller for this
brushless motor
and i am using Wolfpack 1800mah 15C 11.1V - 3 cell
so will the battery will work with the 70amp ESC. its Specifications are :
Constant Current: 70A
Burst Current: 80A
Battery: 4-8S Lipoly /12-24 Volts NiXX
Motor Type: Sensorless Brushless
I just googled the motor and this is what i found.
Propeller dimensions: 12" x 6"/12" x 6.5"/13" x 8"
