I'm getting ready to program my HobbyWing esc for my Gaui X3L On my programming sheet there's 10 items listed to set up the esc. When I plug the box into the esc, it has 16 items instead
. Most of the items listed are self explanatory but some I'm not sure of. I'm wondering If I should just use the default setting or not. The Xnova motor I'm using mention my timing should be 18 degree or higher instead of the default setting of 15 degree and the PWM should be 24 or default which is 32. They don't mention the Gov. Parm P/I setting. There's a few other things like cut off volt, brake force, restart accel, Active FW and so on that not listed on the sheet they give you. The program box has 6 more items then the sheet. All of these setting that Xnova list are for 50a esc and I'm using 60a esc. Any difference? My question is which ones to worry about. I assume the Gov Param. P/I is one of them. Flight mode elf or storage, I've heard use storage instead of elf. Cut off volt and restart accel. is another. I just don't want to put the heli in the air and find out it's running to hot. Any help would be appreciated
