here is all three batteries from my session yesterday trimmed it to around 12 minutes.
flight 20130106 piros and circuits - YouTube
Anytime that happens its a good day. It definately gets the blood pumping exspecially on the bigger helis.During all this I managed a close call while nose in and was ready to dodge it, but I managed to get tail in while almost on the run. Super scary and all is good.
Going home all in one piece.
Seriously? I thought that the helicopter tilted sllightly? All my helicopters tilt very slightly. I thought that was normal at least according to rchelicopterfun.comMatt,
If your MCPX is drifting off during piros, its normally because the swash isn't level. In a hover the FBL unit will compensate, but in a fast spin the slightly unlevel swash will cause it to drift. I had this happen to me. Couldn't understand why it would dive off to the side on piros. Then i took extra care to get the swash totally level and now it piros on the spot.
That's what I thought so maybe they are refering to something different. I can hold the stick to one side and after about 3 revolutions the helicopter ends up off axis if you dont make any corrections. For me I use this just to throw the hellicopter into a wierd pattern then try and correct it as quick as I can. Its worked for me as a training aid.All helicopters with a tail blade will lean to one side to compensate from the thrust of the tail.
Its very tempting to bail out of nose in without making an attempt to save it. I use to do it all the time. Then one day i said "right i'm gonna hold it nose in for a whole battery. I did it. I was sweating and my legs were shaking. But after that my flying skill level increased exponentially.
