Erfan
Hi
I just setup my new Ikon on my t700e. The swash is perfect level on the bench when doing the swash setup, the blades are also balanced and I have a -12 - +12 pitch with almost 0 at mid stick.
Got it out for my first test run and tail holds, it feels great but it has kind of heavy AIL tilt to the left, not a slight drift which you could fix by AIL gain, instead it feels like the stick actually gives left AIL command, its really noticeable and doing nothing for couple of seconds and its really hard going to the left.
There are no sub-trims or trims at all, the swash is level and I cannot notice any vibrations...
I guess adding some trim to counter is no good on any fbl? At least I know its a no go on 3gx, not sure about Ikon. Also it feels you just take a bad shortcut using trims since it should not be needed if mecanical and software setup is perfect, I'm right?
Any suggestion?
Any suggestion?
