Re: It's starting
And here is more. This is the own FAA's docket regarding the hobby...
[Docket No. FAA-2014-0396]
Interpretation of the Special Rule for Model Aircraft
AGENCY: Federal Aviation Administration (FAA), DOT.
ACTION: Notice of Interpretation with Request for Comment
SUMMARY: This action provides interested persons with the opportunity to comment on the FAA’s interpretation of the special rule for model aircraft established by Congress in the FAA Modernization and Reform Act of 2012. In this interpretation, the FAA clarifies that: model aircraft must satisfy the criteria in the Act to qualify as model aircraft and to be exempt from future FAA rulemaking action; and consistent with the Act, if a model aircraft operator endangers the safety of the National Airspace System, the FAA has the authority to take enforcement action against those operators for those safety violations. ------------------------------------------------------------------------------------------ SEC. 336. SPECIAL RULE FOR MODEL AIRCRAFT.
(a) In General.--Notwithstanding any other provision of law relating to the incorporation of
unmanned aircraft systems into Federal Aviation Administration plans and policies, including
this subtitle, the Administrator of the Federal Aviation Administration may not promulgate any
rule or regulation regarding a model aircraft, or an aircraft being developed as a model aircraft,
if--
(1) the aircraft is flown strictly for hobby or recreational use;
(2) the aircraft is operated in accordance with a community-based set of safety guidelines and
within the programming of a nationwide community-based organization;
(3) the aircraft is limited to not more than 55 pounds unless otherwise certified through a design,
construction, inspection, flight test, and operational safety program administered by a
(4) the aircraft is operated in a manner that does not interfere with and gives way to any manned
aircraft; and
(5) when flown within 5 miles of an airport, the operator of the aircraft provides the airport
operator and the airport air traffic control tower (when an air traffic facility is located at the
airport) with prior notice of the operation (model aircraft operators flying from a permanent
location within 5 miles of an airport should establish a mutually-agreed upon operating
procedure with the airport operator and the airport air traffic control tower (when an air traffic
facility is located at the airport)).
(b) Statutory Construction.--Nothing in this section shall be construed to limit the authority of
the Administrator to pursue enforcement action against persons operating model aircraft who
endanger the safety of the national airspace system.
(c) Model Aircraft Defined.--In this section, the term ``model aircraft'' means an unmanned
aircraft that is--
(1) capable of sustained flight in the atmosphere;
(2) flown within visual line of sight of the person operating the aircraft; and
(3) flown for hobby or recreational purposes.
