Yeah, I have a 47 gram 1000kv motor on my current RCH Trainer and it seems to work pretty well. The plane is not a "Speed Demon" or anything, but it does fly and the motor and ESC don't get warm. I'm pretty happy with it.
Made some adjustment to the rudder and nose which made a huge difference. Ended with a bump as the wind was gusty just at the wrong time. I still need to add some more dihedral to the wings to give it more stability.
That looked MUCH better Lee. I may have to make some mods to the nose of the fuse on teh plans. I'm already going to modify (actually I have) the elevator and rudder. Made the rudder 1/2" longer, adn there is no notch in the elevator now. Can't wait to see the plane with new dihedral.
I just finished updating the plans to reflect the new tail feathers, extended the nose by 1/2", and incorporated your wing design with the folding. I also added the specs on the electronics that I used on mine. We will see how it does.
After putting more dihedral in the wings, she flew a lot better. But i have come to the conclusion that this is not ment to be a 3ch plane, and should be left as Tony designed it
One change that may make it more stable would be to reduce the aerofoil at the tips. Cut back the top and middle layer to the same as the distance from the trailing edge. Maybe this isn't necessary with ailerons, but i found that my wing had very bad tip stall.
I will rebuild this plane again once i arrive in Mexico, and keep it as it was ment to be built.
Your plane looks really good in the sky. I really like the low and slow passes that you were doing. Very nice!
You were saying above:
Maybe I'm just really tired and worn out from work last night, but I'm not understanding what you are meaning. Can you explain a bit more about this change that you are thinking about?
You see how the wing steps down from leading edge to trailing edge? Well i was thinking to do the same for the wing tips. So it steps down the closer you get to the tip from 3>2>1 layer of foam board. This will reduce the lift at the tip and hopefully stop them from stalling so easily. As i said, i will build it as Tony has in the plans with ailerons, test it again and maybe try the thinner tips.
I actually like that idea. I think it would make the wing look better as well. May have to work on this if I get time. One thing to remember though, these planes with wings like this, fly more with incidence than lift from the wing. So I'm not sure it will actually "help" much.
